Author Topic: A stuck at home electronic to-do list  (Read 820 times)
Offline cvancTopic starter
« on: April 06, 2020, 12:45:15 am »
I'll start...
Check the motor start/run capacitors on your HVAC blower motors!  Mine were both ~30% low and replacing them made a significant difference.  They run stronger and smoother now.
So, what else should we do with all this time and test equipment?  Speak up!
Offline ArthurDent
Re: A stuck at home electronic to-do list
« Reply #1 on: April 06, 2020, 01:08:47 am »
After staying home all this time I just realized that the person sitting on the other side of my breakfast table was my wife! I also realized that the reason I hadn't finished all my electronics projects had nothing to do with with having enough time.
The following users thanked this post: egonotto, SilverSolder
Offline m3vuv
« Reply #2 on: April 06, 2020, 02:08:54 am »
Ive got a shitload of electronic stuff to be getting on with but most of my test gear is on a job 60 miles away that i cant get to them due to the lock down,had to order replacement meters etc!!
Offline Electro Detective
« Reply #3 on: April 06, 2020, 04:19:34 am »
The undisputed winner of the  -Bad Luck Award-   at this thread   :o
« Last Edit: April 09, 2020, 09:54:01 am by Electro Detective »
Offline Haenk
« Reply #4 on: April 06, 2020, 11:51:14 am »
Sort your box of mixed caps. Then continue with the box of mixed resistors. Next the "misc" box. And don't forget all those various screws, nuts and bolt ;)
Luckily, we are still allowed to work at our office, not much to do though, so getting home early and doing some gardening'n'stuff.
