While troubleshooting a Kenmore vacuum that lost power to the power head, I discovered that I lost continuity on one leg of the AC wiring along the wand. After tearing the wand apart (P/N KC99PCPMZV06) I discovered the manufacturer embedded a 10A pico fuse in the wand which was totally covered in plastic. If the fuse blew you now faced replacing a 20 cent part with a new $80 wand.
Thanks for letting me vent. I hope this helps someone, someday. Now I can go back to troubleshooting the dirt sensor which was the original problem.
