Let's try that again, and welcome to further debate if I'm NQR on this (a path traveled countless times btw)
A 500ma bog standard AC to
Regulated DC adapter may cost a few dollars more (and maybe not)
but gets rid of those open circuit vs loaded up concerns of 'good enough/hey, it works' penny pinching and or Approval Friendly manufacturers unregulated adapters.
bdunham7's cat feeder device will receive the required 9 volts at any current/load demand, be it steady and or fluctuating, from the sticker rating of 120ma max or less,
or more if required up to a generous reserve of 500ma
and...keeps the show on the road at 9 volts DC
during freaky AC voltage fluctuations from 180 to 260 volts during peak and off peak demand in the street/suburb
Why gamble on an unregulated cheapo that may work 'ok' out of the box, and cash out later, or cause the cat feeder drama?
@ bdunham7, do you have a photo of the cat feeder's DC requirements? Does it specifically state 9 volts DC at ???ma
I've used these before, and even though I prefer old school transformer based ones, they work great
www.jaycar.com.au/switchmode-plugpack-9vdc-1-66a/p/MP3484This one has a fixed positive tip (assuming it's listed plug dimensions/specs are same as yours) and ready to go.
www.altronics.com.au/p/m8925c-powertran-9v-dc-2a-fixed-2.1mm-tip-appliance-plugpack/This one is cheaper, 500ma and should suffice:
www.altronics.com.au/p/m9273a-powertran-12v-dc-0.5a-fixed-2.1mm-tip-appliance-powerpack/The more 'ma' the better I reckon, and you can use them with low or higher powered devices
FWIW: I'm here to pitch for the cats, so they don't miss out on a feed
and or whiff a smouldering adapter.
