Author Topic: AC motor control - Forward-Stop-Reverse  (Read 890 times)
Offline rocmelTopic starter
« on: December 27, 2022, 03:44:25 am »
I have a garden chipper/shredder that the mechanical stop, between Fwd - Reverse is damaged.(fig1)
it uses an induction motor with an external starting capacitor
Brand "Wolf Garten SSD2200" 230v 2200W
The Forward switch is working fine, can't remember if reverse is working
The original Switch is complicated using a relay with multi contacts, no longer available
Looking for ideas how to achieve the STOP in between Fw -R
& discharge the starter capacitor 15uf in between switching.
Offline abdulbadii
Re: AC motor control - Forward-Stop-Reverse
« Reply #1 on: December 28, 2022, 11:28:01 pm »
isn't this better under repair forum section?
just unscrew that part hopefully it's easy to find and fix the H bridge circuit; 1 mechanical/kinetic external switch action is to drive internal 2 ones, a stop switch will prevent any contact on internal switches
https://en.wikipedia.org/wiki/H-bridge#:~:text=A%20H%2Dbridge%20is%20an,to%20run%20forwards%20or%20backwards.
« Last Edit: December 28, 2022, 11:38:12 pm by abdulbadii »
« Reply #2 on: December 29, 2022, 01:17:46 am »
My question was
 Thanks , your answer does not address the fact that is AC the capacitor placement determines the rotation
or how to discharge the capacitor before changing direction of rotation.
Offline abdulbadii
« Reply #3 on: December 29, 2022, 01:50:52 am »
Forgot this' AC, sorry
Imho in AC instead of H it uses pole, throw or akin stuff configuration (but can't figure out yet as in big business else)
Offline Vincent
  • May or may not be a Tektronix fanboy
    • The Vince Electric Laboratory
« Reply #4 on: January 01, 2023, 01:13:44 am »
I remember this stuff being discussed back in trade school, but it's already been over a decade since then.
If I remember right, you need to reverse the direction of the rotating magnetic field. With 3-phase motors it's a piece of cake, just interchange two of the phases.
With single-phase motors things get a bit more complicated. You need to "flip" the phase angle between the start and run windings. With some types, like shaded-pole motors, it'd be rather difficult to do. Others use starting capacitors and these may be easier to hack to make them start in the other direction, maybe by designing a starting inductor, creating a phase angle opposite to that of the capacitor?  :-//
On a related note, aren't there (single-phase) induction motors specifically designed to rotate in both directions?
Online IanB
« Reply #5 on: January 01, 2023, 01:35:00 am »
My question was
You have not given enough information in your question for an adequate answer to be provided. I cannot tell from what you have said whether the switch is defective, the relay is defective, or both.
You apparently don't even know yourself:
The Forward switch is working fine, can't remember if reverse is working.
Please don't post questions until you have at least got the basic facts in order. Otherwise it just wastes everyone's time.
The short answer: reverse engineer the existing switch and wiring, then repair or replace with equivalents as needed.
The long answer: do a detailed photo-by-photo disassembly, showing every detail of the construction, and post the photos here. Show where and why you think a part is defective. Explain where you have a problem getting a suitable replacement or substitute part. Remember the easiest way to repair something is to keep the wiring exactly the same as the original design. Redesigning a circuit to repair something needs much more expertise.
A replacement for a relay is always available. It may have physically different shape, and maybe it is not the exact part originally installed, but relays are universal. You just need to find one of a similar size and rating and figure out how to fit it in the place occupied by the original.
Additional information: single phase induction motors are reversed by swapping a single pair of wires. This requires either a DPDT switch, or a relay that performs the same function. The motor has to be stopped before trying to switch direction. If the motor is still turning when you try to change the direction, the chances are that it will keep going the same way.
