Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
[solved] Asus VE276Q monitor with unidentified burnt component
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: [solved] Asus VE276Q monitor with unidentified burnt component (Read 385 times)
crozenfox
Newbie
Country:
on:
August 12, 2024, 09:55:31 pm »
Hi all,
My monitor no longer works. There is one component that burned.
The monitor is an Asus VE276Q.
Can you identify this component ?
The reference is something like LT2124 631006 if i see it right !
Thanks
Last Edit: August 16, 2024, 09:29:26 pm by crozenfox
Logged
fzabkar
Super Contributor
Country:
Re: Asus VE276Q monitor with unidentified burnt component
Reply #1 on:
August 12, 2024, 10:38:09 pm »
I'm guessing it's a 100V, 3A Schottky rectifier (B3100B ??).
Similar to ...
https://datasheet.octopart.com/B3100-13-F-Diodes-Inc.-datasheet-7554362.pdf
https://www.onsemi.com/pdf/datasheet/mbrs3100t3-d.pdf
Page 14 of the datasheet for the MP3389 shows a B180 diode:
https://www.monolithicpower.com/en/documentview/productdocument/index/version/2/document_type/Datasheet/lang/en/sku/MP3389/document_id/1533/
Last Edit: August 12, 2024, 10:44:31 pm by fzabkar
Logged
crozenfox
crozenfox
Newbie
Country:
Reply #2 on:
August 13, 2024, 11:02:50 am »
Thank you very much. You are great !
I found two components :
One is a SMC case with a 200pF capacitance while the other one is a SMB with 105pF capacitance.
Here are the links :
https://www.tme.eu/be/en/details/b3100-13-f/smd-schottky-diodes/diodes-incorporated/
https://www.tme.eu/be/en/details/b3100be-13/smd-schottky-diodes/diodes-incorporated/
What do you think should i try ?
Logged
fzabkar
Super Contributor
Country:
Reply #3 on:
August 13, 2024, 11:28:18 am »
I would use whichever diode has the correct dimensions. Check the output for short to ground.
Logged
crozenfox
Newbie
Country:
Reply #4 on:
August 13, 2024, 07:12:53 pm »
ok
The dimensions are this one. So, i will try with it. Thnx
Logged
crozenfox
Newbie
Country:
Reply #5 on:
August 16, 2024, 09:28:50 pm »
Job done. Works very well !
Thank you a lot, this forum is great !
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
