Thank you SRB1954
The battery was replaced due to the original having lost its power and it probably means that all calibration data was lost before I took ownership.
Even though the analyzer passes its internal calibration routine, it's probably off.
The relays can also generate a calibration fail message and someone recently was able to adapt newer relays to resolve the issue. I have those adapter boards and relays ready and waiting to be installed.
I do not plan to replace the SRAM but I intend to add the additional DRAM.
The service manual has a step-by-step procedure to calibrate the analyzer so the future still looks bright for this machine
