Author Topic: ACD 30" Part Identification  (Read 2607 times)
Offline EEV_TechForum_drbTopic starter
« on: October 17, 2022, 02:10:38 am »
Ref:     Apple Cinema Display 30” A1083
Model: M9179LL/A
MLB:   LAQ55C Rev 3 Eax35328203
Greetings:
I discovered a missing diode, D204, while bench testing the MLB in the above reference, please see attached.
The smd code for the diode would be very helpful.
Thank you
Offline fzabkar
Re: ACD 30" Part Identification
« Reply #1 on: October 17, 2022, 07:33:57 pm »
Can you identify U201?
Are your sure D204 isn't normally unpopulated?
« Reply #2 on: October 17, 2022, 11:04:03 pm »
1/ U201 is a voltage detector whose set point is Vs = +2.9v.  It throws a logic low to the uC reset pin during power up and sudden power interruptions.
smd code 6F, device P/N KIA7029AF/AT
2/ Upon closer examination with a 20x eye loop, it appears that the solder connections for D204 are smooth and of factory quality therefore intentionally unstuffed.
Thank you so much for asking the question.
I think I'm good for now
