Author Topic: Acer AL1916 monitor PSU repair (DM0565R blown)  (Read 9042 times)
Offline 807Topic starter
« on: April 11, 2024, 03:42:21 pm »
I'm repairing an Acer AL1916 monitor PSU at the moment. The 400v high voltage smoothing capacitor C114 is measuring completely O/C. The case of U101 has blown apart. Fuse F101 has blown. ZD121 reads 6 Ohms in both directions & ZD120 reads 99 Ohms in both directions. While looking at the data sheet of U101 (DM0565R), I noticed that the absolute maximum voltage for Vcc is 20v. However, the zener diode across the Vcc pin to GND is a 1N4748A (22v).
Now, whether that zener is used to constantly regulate the voltage, or whether its's used to protect the Vcc voltage from rising too high, I can't understand why 22v was chosen, given that the absolute maximum voltage for that pin is 20v? Wouldn't a 20v or 18v zener have been more appropriate?
Until the replacement components arrive, I dont know what voltage the auxiliary transformer winding is supplying to the Vcc pin of the DM0565R.
Offline fzabkar
Re: Acer AL1916 monitor PSU repair (DM0565R blown)
« Reply #1 on: April 11, 2024, 11:50:40 pm »
I would consider replacing C123 as a precautionary measure, even though it is probably fine.
As for the choice of Zener voltage, that puzzles me, too.
« Reply #2 on: April 12, 2024, 11:06:15 am »
Yep. I'll replace C123 as well as C120 and the optocoupler. Even though they all check out OK, it looks like U101 broke down & put a high DC voltage on the Vfb & Vcc pins.
