Author Topic: Acer Monitor 1716F Power Supply  (Read 1141 times)
Offline paul_g_787Topic starter
« on: January 04, 2021, 05:50:32 pm »
Hi.
Thought I would share this one as I have never seen anything like this before. My office monitor would not switch on the other morning so though I would have a quick look.
Never seen an IC exploded like this before. :) Oh dear.
I have found replacement ICs on eBay. They are an Alpha and Omega AOP605. The exploded one had a direct short on pin 3 and 4!!
Anyway I have ordered replacements for the bulging capacitors. They are Suscon brand??? I am replacing all of them just to be safe.
Can anyone find the schematic for this board??
I cannot find the datasheet for my revision monitor 1716Fs
I cannot see any other faults or find any other shorts. Any advise on what else to check?
Re: Acer Monitor 1716F Power Supply
« Reply #1 on: January 04, 2021, 05:55:09 pm »
A couple shots here of the power supply
Offline kripton2035
« Reply #2 on: January 04, 2021, 05:59:44 pm »
i would change the blown circuit
and the two bulky caps you can see on the picture
and test the esr of the other chemical caps.
Offline fzabkar
« Reply #3 on: January 04, 2021, 07:28:09 pm »
Are any of these models similar to yours?
https://elektrotanya.com/showresult?what=acer+AL1716&kategoria=All&kat2=All
BTW, I would be very suspicious of MOSFETs source through eBay.
Offline SpecialK
« Reply #4 on: January 04, 2021, 09:02:48 pm »
I'm not sure where you could find an AOP605 other than eBay.  I haven't had luck obtaining A&O from Digikey or Mouser.
Offline kripton2035
« Reply #5 on: January 05, 2021, 07:06:46 am »
yep there are not a lot of sellers out there for this device
https://octopart.com/search?q=aop605&currency=USD&specs=1
Offline SpecialK
« Reply #6 on: January 05, 2021, 02:58:05 pm »
That link says 2 results.  The first says min $100 order,  the other to ask for a quote.  Probably need to order a spool of 2500.
« Reply #7 on: January 06, 2021, 09:41:00 pm »
No it appears they used several different power supplies. I have already looked at those and they don't match unfortunately. Mine is the 'F' model - AL1716F
