Hello everybody
I'm trying to repair my Acer PC monitor. I found that the power supply has some issues. A transistor (SSS6N60A, N-Channel Mosfet) is obviously broken. The drain source path stays conductive all the time!
My question is, if I can replace the SSS6N60A with a newer 2SK2645.
Attached you can find the required datasheets.
Thank you in advance!
