Author Topic: Acquired a military multimeter AN-PSM-37,Intend to fix it  (Read 1863 times)
Offline daisizhouTopic starter
  • Country: cn
« on: February 27, 2021, 03:48:21 am »
Want to know if any friends are still using this kind of multimeter?
Found that there are 5 legs of the op amp, I don’t know what model it is,Can anyone tell me the exact model number?
[ Specified attachment is not available ]
« Last Edit: February 27, 2021, 03:52:01 am by daisizhou »
daisizhou#sina.com #=@
Offline xavier60
Re: Acquired a military multimeter AN-PSM-37,Intend to fix it
« Reply #1 on: February 27, 2021, 04:47:21 am »
The selectable voltage input  sensitivity including 10MΩ looks interesting. FET input stage maybe?
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
  • Country: cn
« Reply #2 on: February 27, 2021, 04:56:06 am »
Yes, there is a 5-pin chip on the internal circuit board,Looks like an op amp
But did not write the model number
Below is the manual, hope you can help me* 33A1-12-933-1_5029.pdf (2342.14 kB - downloaded 71 times.)* 33K1-4-141-1_4468.pdf (747.27 kB - downloaded 89 times.)
Offline bob91343
« Reply #3 on: February 27, 2021, 06:24:25 am »
What is wrong with it?
  • Country: cn
« Reply #4 on: February 27, 2021, 08:16:35 am »
Pointer does not turn,Estimated to be damaged
Offline xavier60
« Reply #5 on: February 27, 2021, 10:59:51 am »
If  you have a working Digital Multimeter, you can do a resistance test on the meter movement's terminals.
I'm not certain what to expect at the moment but the pointer needle should also move.
The following users thanked this post: daisizhou
  • Country: cn
« Reply #6 on: February 28, 2021, 04:51:57 am »
Has anyone used this kind of meter?I hope friends who know or know can help me
Offline Stray Electron
« Reply #7 on: February 28, 2021, 05:22:31 am »
  The date of the contract for that meter appears to be 1974 but I've never heard of that company!  My guess is that they were a small shop that got part of a large contract to build meters (not a standard design either) along with many other small companies. I have a big "automotive electrical system" tester that falls into the same category. I've seen many "automotive electrical system" testers that were purchased under the exact same military classification as mine and meet the same requirements but they're all different and were built by at least 6 different companies. It's also quite likely that that company that built your meter only existed for as long as it took to build the meters to complete that one contract. FWIW the tester that I have was built in a town about 10 miles from where I live and I know many electronics types in the area and none of them have ever heard of the company!  However I got lucky in that even though my tester is about the same vintage as your meter, it had been completely overhauled in about 1982 and then placed in a sealed box that wasn't opened for about 30 years and it included two complete copies of the manuals for it.
« Reply #8 on: February 28, 2021, 05:24:48 am »
   That meter movement takes 50 microamps DC for Full Scale movement. It's marked on the scale.
« Reply #9 on: February 28, 2021, 05:28:50 am »
  Have you seen this?  http://www.nj7p.org/Manuals/PDFs/Military/TO%2033A1-12-933-11%201-May-87%20K4XL.pdf
   Look at the next to the last page.
« Last Edit: February 28, 2021, 05:33:28 am by Stray Electron »
Offline xavier60
« Reply #10 on: February 28, 2021, 05:37:42 am »
Can you post some internal photos?
Are the battery contacts intact?
  • Country: cn
« Reply #11 on: February 28, 2021, 08:50:42 am »
Yes, I have checked this model.They look alike, and the internal circuits are basically the same
The only difference is the safety protection device
I am trying to disassemble it
Offline xavier60
« Reply #12 on: February 28, 2021, 10:29:44 am »
With no battery power, that multimeter will not even work on the voltage ranges.
More conventional analog multimeters need battery power only for the resistance ranges to work,
Offline Wallace Gasiewicz
« Reply #13 on: March 01, 2021, 12:07:24 pm »
I have one of these meters and have repaired it. It is a good meter. Use it all the time. There is somewhat of a following of fans on some military equip post sites
It is more like a VTVM or modern digital meter in that it amplifies the input to achieve a high input impedance, so it loads down the circuit very little.
To check the mechanical D'Arsonval meter itself, just touch it with resistance probe of a multimeter.
There is a FET jnput and the op amp is pretty standard, as I recall.
This thing takes a LOT of batteries. I am attaching the Manual with some schematics.
Wally
« Last Edit: March 01, 2021, 12:11:44 pm by Wallace Gasiewicz »
