Author Topic: Component identification from SansAmp Bass Driver DI  (Read 1762 times)
Offline MRiddickWTopic starter
  • Unprofessional Engineer
« on: October 23, 2020, 11:52:44 pm »
Hi all,
Does anyone have any idea what this component might be? It's from a Tech21 SansAmp Bass Driver D.I. (gen 1). No markings other than "CH34-4" and pin 1 indicator. Same on the other side. SIP-8 package.  My first thought was a SIP resistor array, but that makes no sense once I think about it more. That said, here's the resistances referenced to pin 1.
Pin 2: 15.2 MOhm
Pin 3: OL
Pin 4: 217 kOhm
Pin 5: 310 kOhm
Pin 6: 440 kOhm
Pin 7: 660 kOhm
Pin 8: OL
I measured these before I realized how ridiculous it would be for it to be a resistor array; why not make the resistors surface mount like all the others? Also that would be about 6 times the size of any other resistor array I’ve seen.
I've sketched out a few of the connections. I'm making it into a readable schematic that I'll add when I'm done, but I figured I'd get this out now in case someone immediately recognizes it.
Thanks!
Altium Designer 20 | EAGLE 7.7
Offline amyk
Re: Component identification from SansAmp Bass Driver DI
« Reply #1 on: October 24, 2020, 12:30:32 am »
The summary is that it's just the manufacturer trying to hide parts of the circuitry from reverse-engineering... which didn't work, because I found some very useful information in here: https://www.freestompboxes.org/viewtopic.php?f=1&t=6571&start=80
Whole thread is interesting too. Sadly a lot of the links and pictures are dead, and the archive.org does not have them either, but you can get most of the info from there.
« Reply #2 on: October 24, 2020, 12:59:35 am »
22 pages! Well I guess I have my reading cut out for me; thanks!
There are a lot of things more depressing than old, broken forum threads, but it's definitely a unique feeling of hopelessness.
« Reply #3 on: November 01, 2020, 03:20:28 pm »
So I don't turn into the thing I hate the most, here's an update: Thanks to you and the thread you linked, I managed to find a few schematics that use the module. Attached is a screenshot of the module portion of the schematic.
