Author Topic: Adding buzzer on Mastech M830-B DMM  (Read 670 times)
Offline StingerTopic starter
« on: December 16, 2023, 01:56:26 pm »
My 90's Mastech M830-B multimeter didn't have beep continuity.
Can i add buzzer in Diode mod ?
Where solder buzzer on circuit ?
Thanks for your help. :)
Offline wraper
  • Country: lv
Re: Adding buzzer on Mastech M830-B DMM
« Reply #1 on: December 16, 2023, 02:09:11 pm »
You'd need to add a circuit like this.
Offline wraper
  • Country: lv
« Reply #2 on: December 16, 2023, 02:13:12 pm »
To here I think.
Online coromonadalix
« Reply #3 on: December 16, 2023, 02:14:07 pm »
more complicated than needed
you have cheap meters who have the buzzer,  if you take time and parts into considerations, it will cost more than a new meter
you need to be sure  the dial position will trigger a buzzer circuit, not jst adding the circuit
« Reply #4 on: December 16, 2023, 08:49:57 pm »
Thank's for answers. I think easiest like seen on YT  ;D
Offline wraper
  • Country: lv
« Reply #5 on: December 16, 2023, 08:58:54 pm »
You need to have some sort of comparator anyway, won't be simpler than LM358 with a few resistors like in M838 circuit. You can use buzzer with built in driver directly powered from comparator to minimize component count (throw out transistor and a few resistors).
« Last Edit: December 16, 2023, 09:01:15 pm by wraper »
