Author Topic: Advance PG59  (Read 1224 times)
Offline NikolaTopic starter
Advance PG59
« on: May 01, 2015, 07:01:15 pm »
Hello!
I have bought an Advance pulse generator PG59 which was made in UK. It was cheap because only one channel worked. Few days ago I took it apart and started looking for an error.
Fault was located at third module and I swapped every single transistor from channel B to A with no luck. Channel B is still operational and the other unfortunately not. Wires and voltages were checked, output signal at A is affected by changing offset but without modulation.
Therefore a problem is in diodes or in resistors ? Capacitors (6) were checked.
I have paid on some site for repair manuals but after a month I got refunded as they were not able to find one.
Does anybody have any suggestions ?
Thank you !
The following users thanked this post: krazh
Offline krazh
  • Country: in
Re: Advance PG59
« Reply #1 on: November 20, 2019, 06:20:36 am »
Thanks for the post, as this is an interesting unit.
I wish I could help, as I too have been looking for any documentation for this unit.
Have you had any luck with manuals ?
Best wishes.
