I cleaned the whole pcb with IPA. It did boot and again restarted multiple times. Now it is dead. No beep
Usually IPA contains also - water. Known to be not a great thing in combination with electronics.
Did you make sure your board was *really* dry (like putting into an oven at 50oC)? IPA will flow below ICs and parts, so if you did not properly dry it, you might have had shorts in one or more spaces.
