It is not wise to trace shorted faults by using power and hope to find a hot spot ,
The reason is if it is a true short you will find the tracks and any other parts in line will heat up and possible burn making things worst.
The way to trace it is to use a ohm meter and isolate areas by cutting connections and or tracks.
That is after a good visual inspection of the components and tracks to see if any clues are there.
Any capacitors that are out of shape take them out !
Trev
