Hello,
I have a R3273 with a problem displaying signals above the low band mixer 3.5Ghz with high spans over about 10 Ghz.
For example, trying to detect a CW signal -10dbm at 12 Ghz on full span , signal is not detected at all on some sweep or has low amplitude on another sweep or has almost correct amplitude on another sweep (signal fluctuate up and down to noise level on different sweeps on the trace) , switching down to 10Ghz or less, signal detected correctly with correct amplitude.
Changing sweep time up or down does not help. Also, changing the YTF offset values does not help either, just under about 10Ghz span works fine.
Any clues what can tha be ?
Thanks
