Hi. I have a reference AMD RV Vega 64 card. It has served me well mining for many months. a few months ago, I went to start up system, and no boot. Now it continues to just turn off the PC like it is shorted.
Things I have done.....
Visually checked PCB for damage power components, etc. but found nothing, no smells, etc. I'm pretty sure I have identified an issue with one or all of the low-side mosfets powering the GPU. Please see attached picture. The IRF6894 mosfets ALL have continuity with ground. The other VRMs all have some resistance, so I would guess its relegated to one of the 12, or all 12 powering the GPU.
I've powered it up multiple times, and have never "let the smoke out", so maybe it is salvageable?
In its current state, I have applied power, and when I reset the computer, I can get the board to give voltage on the low-side mosfets of about .2V-.8V for a few seconds before, I assume the controller shuts it down because something isn't right.
My questions......
1) Is is safe to assume that one shorted mosfet will cause all of them to be grounded? Or would it be all that grounded
2) Likelyhood that core chip is toasted?
3) Anything else that would cause fets to be grounded across the entire board?
Any help or suggestions on next steps would be greatly appreciated! Cheers!
