I have an Advantest R6144 here that I've finally got back around to repairing after having it sit on the shelf for years....
So far it is all working ok in regards to the user interface, no errors, battery is good, etc etc. I found a bad chip or two on the top logic board which have been replaced.
I tested every.single.chip on this board besides the CPU, and a one or two others that I can't test, using my Retro Chip Tester Pro, so as far as I can tell, all the logic board seems to be working fine.
My problem is when I try to use the 1.6V, 160mV and 16mV ranges I get bad output.
On the lower main board, I originally found a bunch of removed parts in a previous repair attempt, so after replacing those parts with new, I went on to test every diode, every transistor, and every relay and all are good.
I have also tested all the precision resistors, and all are also well under tolerance by an order of magnitude, save the 2ohm R56, that is reading 2.3033ohms (4-wire measurement) or 15.17% high.
The voltage reference (LT1021BCN8-7) also appears to be good, as the upper ranges works perfectly and are spot on.
I haven't tried replacing the associated opamp yet (LT1008CN8/NA) as that part of the circuit seeeeemssss ok, but maybe that could be an issue?
I thought maybe something in the feedback circuit somewhere (oh how I wish for schematics!) so as part of replacing missing parts, I also replaced U9 (LM324N), U10 (LM339N) and U8 (C812C) opamps so they are good.
Today for the sake of it, I replaced U7 (OP77) which was an original part with a better spec OP177 part to no change.
So, besides the 2 ohm resistor I have to figure out, does anyone have any ideas where I can poke to get this thing running?
I have made a graph of the output in the affected ranges (all other ranges work perfectly), linked below.
