Author Topic: Advantest R6581 Display Needed  (Read 1990 times)
Offline TheDefpomTopic starter
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« on: September 23, 2022, 03:25:05 am »
Hi All,
I have been working on a Advantest R6581 8.5 digit (ish) multimeter which seems to be basically working (and yes I have been doing a video about it), but as usual with this type of gear the display is very dim, I am hoping someone out there has a known good display (with very little/no burn in) so that I can get this looking a lot better.
If you have one it will be shipping to New Zealand and payment will be done via PayPal.
Cheers Scott
Offline coromonadalix
Re: Advantest R6581 Display Needed
« Reply #1 on: September 23, 2022, 01:37:53 pm »
do you have a part number / model,    since its an 2 line vfd  would it be substituable with an lcd instead ???
Offline picburner
« Reply #2 on: September 24, 2022, 04:16:29 am »
No, a simple two-line character display is not enough, you need a graphic display.
In fact, as you can see from the attached picture, there are also symbols at the top of the screen.
Then you should do a decoding as I did some time ago for the Wavetek 1271.
I also have an R6581T with a barely readable display, I confess that for a moment I thought about doing a similar thing but then I gave up.
Offline aronake
  • Country: hk
« Reply #3 on: May 03, 2023, 11:00:38 am »
Have anyone had any success in finding a display or some alternative solution?
« Reply #4 on: May 03, 2023, 11:10:48 am »
Not yet, I got mine brighter but it still is in desperate need of replacement
Cheers Scott
Offline aronake
  • Country: hk
« Reply #5 on: May 04, 2023, 04:48:57 am »
Thanks. I saw your video while searching for this. Good work both on video production and repair work!
Good there is the LCD display hack in case anything else fails.
Offline aronake
  • Country: hk
« Reply #6 on: May 04, 2023, 04:48:04 pm »
I'll be in Akihabara next week, so will search around. If any place to find one of these displays, that should be a good place.
Offline branadic
  • Sounds like noise
« Reply #7 on: May 04, 2023, 08:14:48 pm »
I was one of the lucky guys getting a new VFD back in 2020 for my unit.
https://www.eevblog.com/forum/metrology/advantest-r6581-8-5-digit-dmm-mini-teardownrepair/msg3245622/#msg3245622
-branadic-
Computers exist to solve problems that we wouldn't have without them. AI exists to answer questions, we wouldn't ask without it.
The following users thanked this post: aronake
Offline aronake
  • Country: hk
« Reply #8 on: May 06, 2023, 05:25:06 am »
Kind of a odd that these ancient displays was manufactured as late as 2017.
