Fzabkar - Sure I can explain those features - sorry for focusing on the motor - I guess I’m being rather tunnel visioned on the thing that isn’t working, but appreciate it’s helpful to understand the broader functions as they maybe connected, and will help understand what is there and why.
Here is a pic of the controls:
There are five motors:
2 delivery wheel motors that shoots ball. They spin at different speeds to send the ball with topspin or with under spin.
1 Oscillation motor aims the two delivery wheels left and right It has potentiometer that connect to the oscillation motor to determine it's position
1 Elevation motor that tilts the delivery wheels up and down to control the trajectory-- has potentiometer to read it's position.
1 carousal motor controls a turning disk with 4 holes (carousal) -the faster it spins the faster balls are released.
There are 6 positions that can be set on the right: The location of the sliders determines where the ball will shoot.
Program delivery will cycle through the positions (1-7) set on the right.
Random delivery will chose a random position to send to. You can turn on or off the position sliders to use any number of the 7 possible positions.
Ball Feed knob/potentiometer: Turn to the right and the faster the carousal spins.
Speed Control knob/potentiometer: Turn to the right and the faster the delivery wheels spin.
Spin Control knob/potentiometer: Turn to the right and top delivery wheels spins faster than the bottom delivery wheel creating topspin. Turn to the middle and both motors run at the same basic speed sending a "flatish" ball. Turn to the left and the bottom motor spins faster than the top motor creating under or back spin.
All of these features work as intended. The exception is that the top motor (controller primarily from the speed dial), as it accepts an additional speed adjustment from the spin dial.
The denounce IC I believe helps the push button that starts/stops The carousel motor (start or stop serving).
Hope this detail helps.
Sent from my iPhone using Tapatalk
