Author Topic: Atlas LCR  (Read 532 times)
Offline PilibTopic starter
  • Country: ie
Atlas LCR
« on: May 01, 2024, 03:11:51 pm »
HI Folks
I am having a go at repairing a Peak LCR40, have found an ic which has an internal short.  The part is 14 pin and marked 45D6JHM 26241 on the top and 01A37 on the bottom.  Have tried searching the internet but have had no luck,  I wondered if any members could offer any advice please?  Many Thanks,  Philip.
Offline Fenstergucker
  • Country: at
    • Private Website
Re: Atlas LCR
« Reply #1 on: May 01, 2024, 04:39:09 pm »
Perhaps a Texas Instruments TLV2624 OpAmp. The '1' at the end is an 'I'.
Peter
  • Country: ie
Re: Atlas LCR
« Reply #2 on: May 02, 2024, 08:05:46 am »
Many thanks Peter,  The markings on the ic are not clear but what's left of the symbol could be Texas Instrument's.  I think you have solved the problem so will order one and try it.
I will let you know as to what happens.
Thanks again,  Best wishes,  Philip.
