Author Topic: Datasheet for Nichicon SE series ?  (Read 345 times)
Offline MathWizardTopic starter
« on: May 02, 2024, 06:26:06 am »
I'm checking some caps in an older stereo from the 1980's, and I can't find much info on Nichicon SE(M) series caps, they are typical looking radial leaded electrolytic's, only 85C rated.
What's similar to them, what table or datsheets might I use to check their dissipation factor or ESR ?
Offline fenugrec
Re: Datasheet for Nichicon SE series ?
« Reply #1 on: May 02, 2024, 05:03:55 pm »
Might try on archive.org or bitsavers, sometimes you can find scans of old catalogs.
Looking at the schematics where it's used will give a clue as to the important characteristics.
« Reply #2 on: May 02, 2024, 06:15:45 pm »
So far their ESR seems pretty good, there's some Elna and Nippion caps as well, I can't find the exact Elna datasheet yet either. But Besides 1 or 2, they seem pretty good, for DF.
But I don't check a lot of caps, so I don't have a good feel for the numbers.
