Author Topic: Advice - Repair a Z-Wave Controller LCD Display  (Read 1428 times)
Online xrunnerTopic starter
  • hp>Agilent>Keysight>???
« on: March 08, 2017, 02:20:51 pm »
Can this LCD be fixed? I believe the cable is not making contact properly. I am not familiar with the way this flex cable is attached. I know about zebra strips but this seems to be glued on - I don't know. Any possibility of fixing it?
Thanks.
Offline bktemp
Re: Advice - Repair a Z-Wave Controller LCD Display
« Reply #1 on: March 08, 2017, 04:03:04 pm »
This failure mode is quite common for this type of connection: When moisture gets in, the glue fails.
Repairing is possible, but if it is not done correctly, it will not last long:
You need to heat up the connection while applying pressure to the connection and let it cool down while holding the pressure.
It can be done using a soldering iron set to a low temperature. It is not the correct way, but often works.
« Reply #2 on: March 08, 2017, 04:35:49 pm »
Interesting. OK, do you happen to know what temp to use? My Hakko can go down to 200 C.
Offline Rasz
    • My random blog.
« Reply #3 on: March 09, 2017, 04:14:37 am »
similar maybe
