Hi all,
I recently came in the possesion of an Aeroflex (IFR/Marconi) COM-120B; it would be an important addition to my small lab / ham shack and I want to try and restore it. It arrived with an Aeroflex label "beyond economical repair" and was told it needs a new Planar display control unit (datasheet:
https://www.eldisplays.com/content/EL560.400-LP.pdf)
Turning it on, this happens:
- one beep, antenna LEDs come on/off one after the other
- 10 seconds later, a sequence of beeps seems to indicate some error code (..._.)
- display never comes on, nothing else happens
- PSU voltages seem to be fine at test points (+12V, +5V, +/-10V all within 5%)
- can't be turned off from the front panel button.
The display control unit looked like someone poked around and tried to redo the soldering (or unsolder to measure and then solder back ?) on one row of the SMPS transformer. One connection was interrupted (wire to pin) so I had to go around and fix all of them; I also checked all transistors/diodes and replaced the SMPS controller IC. Didn't help.
In fact, it looks like the display control unit is not getting the Enable signal from the display unit so probably that's why the 250V voltage is not coming on. The EL560.400 display unit is supposed to turn on when it detects video signal, however on the 4 video signal pins only clock is present (wave form below) but no Hsync / Vsync / Vdata. Looking at the Digital Tray, the TMS34010 graphics processor doesn't output any video signals and all the HD0-HD15 I/O bus pins are stuck on HIGH.
This points to the Controller Tray not providing the video data, but I have no idea where to start. Visually it looks good (no leaked caps etc) and the Lihium battery measures 3.695V.
Questions I'm trying to find an answer to:
- what does the audible error code (short-short-short-long-short beeps) mean ?
- is the Planar EL560.400 display unit supposed to start when it sees the video clock signal, or it waits for the other signals ?
- any other suggestions on how to approach this ?
Any help is very appreciated.
Thank you,
Razvan.
