The Pace series of products and their "technologies" are so confusing.
At some point, it seemed they are essentially retiring their SensaTemp technology, to be replaced with their IntelliHeat (black vs. blue connector) - at least if you look at their "gender-bender" adapter. And yet, I seem to see SensaTemp on new products (such as the MB360), while IntelliHeat not so much. Then there's a the AccuDrive (which seems to only apply to soldering handpieces), and I just learned there's also HeatWise (?), which I don't even know where it is used and what it even means, as a "technology."
I gathered the info into a post a while back (when the multichannel version was still expected to be called MBT 450, rather than the MBT 360 it became):
What I am curious about is whether the MBT 450 will support SensaTemp or IntelliHeat handpieces. If so, it may be by having dedicated ports, like the short-lived HeatWise MTS stations did.
FYI, some info I cobbled together recently:
SensaTemp (6-pin black connector): their earlier standard for temperature-feedback handpieces. Still around today thanks to continued military purchasing of the PRC2000 which has been around for decades.
HeatWise (4-pin red connector): short-lived type supporting only two handpieces, Pace’s first cartridge based iron and a tweezer. These stations mostly had one or two black SensaTemp ports as well, for the other handpieces.
IntelliHeat (8-pin blue connector): successor standard that combines both SensaTemp and HeatWise signals into one connector, allowing both “native” IntelliHeat handpieces using either SensaTemp or cartridge heating, as well as SensaTemp handpieces via an adapter.
AccuDrive (4-pin black connector): second-generation, higher-power cartridge heater type. Given the 4 pins, I assume there’s no way to add backward compatibility in it, so I expect all-new handpieces.
(They’re all Amphenol C091B series circular DIN connectors, by the way.)
In essence, for their closed-loop temperature-controlled handpieces*, they've only ever had three electrical standards: SensaTemp, HeatWise, and AccuDrive. Every handpiece uses one of these three electrical standards: TD-100 uses HeatWise, TD-200 and MT-200 use AccuDrive, and everything else uses SensaTemp.
Multiple versions of most of the SensaTemp and HeatWise handpieces exist because of different connectors:
AccuDrive has only ever been provided in a dedicated (single-standard) connector. SensaTemp and HeatWise existed in both dedicated connectors (6p black and 4p red, respectively), as well as combined in the IntelliHeat connector (8p blue).
Basically, what Pace did with the release of the MBT 360 is to fully discontinue the HeatWise signaling, by ending the IntelliHeat connector, too. So now we have AccuDrive (4p black) for irons and tweezers, and SensaTemp (6p black) for the other tools, in both cases using only the dedicated connectors.
*That is, expressly excluding their earlier systems which were power-controlled, but not temperature-controlled. These variously used 120V AC or 24V AC handpieces, with essentially dimmer circuits to control power.
