Hello there,
I'm trying to do a cool little trick to program the 2716s with the TL866II Plus.
First point with an eprom directly in the device everything is fine:
1) reading ok, pin detect ok etc ...
2) writing ok by applying an external 25 V on pin 21 (pin out of the support of course), the pin detect and verification must be deactivated but after returning to 1) reading is perfect
Bend pin 21 : it's ok once, it's ok twice ... but quickly it breaks ... hence the assembly, see pictures.
It's not complicated. We shift everything directly to a zif next to it except pin 21 which goes through a jumper that we can put in read (connected to the programmer) or write (connected to VPP). The 0V and VPP pins are used to connect the external 25V. No need to bend the leg anymore ...
Well simpler there is not ... but it does not work !!! Already pin detect not ok and fanciful eprom reading if ignored ...
I had already tried with a more complicated assembly (see here
https://www.dr-bosch.com/volker/umbau/index.html) and which did not work either ... Well I said to myself there are diodes, not exactly the same references, ditto for the transistors etc... in short I did not insist ...
But there ... I tell myself that I understood nothing...
Of course everythins has been check, continuity and zif ok and no short !
If you have any ideas i'm listening.
Regards
Philippe
