Hi all,
I have an older function generator, an Agilent 33120A, that apart from the rotary encoder and putting out twice the stated output voltage, works great. The rotary encoder I can fix, it either needs replacement or cleaning. The output voltage is more confusing to me. I don’t have much experience with repair, I mostly make simple analog stuff so I don’t really know where to start. Maybe it’s just a setting issue, but going through the manual I don’t see anything that points to this issue. The output voltage is exactly double; if I tell it I want a 1kHz sine wave with 1Vp-p, I get a 1kHz sine wave with 2Vp-p. Same with square, triangle, and other waveforms.
Any idea where to start? Thanks in advance.
