Hello circuit wizards!
I have this 120VAC to 12VDC (rated at 5A) power supply that came with an Igloo cooler. I am also using it to power a (cheapo) 12VDC air pump (DC motor with impeller) to inflate/deflate our air mattresses.
The problem: Switching on the air pump causes the motor to make ~ 1/4 turn, and then stops.
My workaround: I have added bullet type connectors on the air pump cable. I switch on the air pump. And then I keep connecting and disconnecting the bullet terminals on one of the wires progressively at a faster rate. The motor starts spinning faster, and after 5 - 6 of this it "catches on", I keep the terminals connected, and everything works like a charm. It feels like I am playing the role of a starter winding in an AC motor...
The need: If possible and practical, find some way so the above power supply and air pump work normally, without my workaround. I am thinking of adding something to the circuitry. Looks like the power supply isn't happy with inductive load.
What I've done:
* The air pump works normally when powered from my desktop power supply. Using 12 - 14V, it draws 3.1A.
* When I have it running off the Igloo power supply it draws 4.2A, and the motor spins faster. When the air pump can't start it draws 0.2A.
* The Igloo power supply shows 14V without load, and a nice, flat, unremarkable line on the oscilloscope.
* The air pump is glued/sealed. Through a grate I can see the two wires connected directly to the terminals on the back of the motor. There's no capacitor, or any anything else.
I am adding some photos. From what I can see, the three legged element with a heat sink on the low voltage side is a SBL2040 Schotkky diode. No clue how that works...
Cheers!
tjk
