Author Topic: Tecpel DMM8007 (8050?) meter issue  (Read 393 times)
Offline Serracin
« on: October 16, 2018, 02:54:02 pm »
This meter has a dead display
And idea from where I shall start please?
Offline coromonadalix
Re: Tecpel DMM8007 (8050?) meter issue
« Reply #1 on: October 16, 2018, 09:54:45 pm »
Check the main ic number, unless it is a black blob
Check your other thread for the schematic it may give you some hints,  they are similar meters ...  you need the backplane drive signal to make the lcd work.
« Last Edit: October 16, 2018, 09:57:47 pm by coromonadalix »
