welcome to teardown... ok it's just a photo gallery but also a quick repair.
My Agilent 33220A 20MHz Arbitrary Signal Generator failed
This is the failure it showed, so the PLL unlocked. Not only this, the unit froze after a few seconds displaying this.
It can only be turned off, the soft power switch still worked surprisingly.
Opening the unit is easy. After taking off the protection rubbers and the handle there are 2 screws at the back (TX20) to remove the plastic holder and then you can take the housing cover off. Well made unit.
To get into the Agilent the inner top cover needs to be removed by unscrewing 2 screws.
The switchmode PSU is attached to the cover. Its a 12V/40W open frame module from Artesyn.
All screws are of same length, very nice.
After a while looking around (see gallery) I started measuring the voltages and found that the entire power supply started to drop all voltages after a few minutes into operation.
So I started tapping tantalum caps to check if any of them gets hot.
I found these on the bottom of the board, and the 2nd from the upper line right was a bit darker.
Well what can I say, that bastard of pure yellow evil burned my finger.
Those tantalum caps are manufacturered by Kemet, according to the service manual (1st edition) they are called "T491..."
I have ordered all 8 of them but they didn't arrive before the weekend.
Since I need the sucker I had to do a quick fix:
This version with 8 x 47µF tantalum capacitors has only been built from around 2003 to 2005.
They changed the design to 10µF ceramic caps at those locations and added 2x 220µF electrolytic caps to those +15/-15V rails.
This is now the 3rd time a Agilent/HP unit fails on me because of those damn tantalums.
I call them "pure yellow evil", first they give you a hassle by making ur unit fail and then they burn your finger if you are not careful.
For those who want to play along here are the links to the service manuals:
Link to Edition 1 Service Manual
http://cp.literature.agilent.com/litweb/pdf/33220-90010.pdfLink to Edition 4 Service Manual
http://cp.literature.agilent.com/litweb/pdf/33220-90012.pdfHere is the gallery of high resolution pictures, enjoy:
