Hi guys,
I have a Hisense 65K560DW TV with problems on the Power Supply Board.
The board number is RSAG7.820.4877 and I have not been able to locate any service manuals or schematics for it.
Forgive me if I explain this wrong or use the incorrect terminology, I am still new to electronics and wrapping my head around SMPS. I cannot find any shorted components or blown fuses, there is no power on any of the rails nor any standby power.
As far as I can tell thus far, the AC power is coming in, going through the rectifier and charging the bulk capacitors, but then that's as far as it goes (the caps are charging to around 400vDC) there is no power on any of the other caps on the output or anything like that.
I usually just fix things like blown MOSFETs or diodes, whereas I cannot find anything to my knowledge wrong so I believe I am in over my head. Any tips of what I should try, or check would be highly appreciated. I have the basic tools such as a DMM and LCR meter if that helps
Cheers
