Author Topic: Agilent 34401A 2w drift and high readings when power up  (Read 10521 times)
Offline Samogon
Re: Agilent 34401A 2w drift and high readings when power up
« Reply #25 on: June 24, 2017, 01:12:31 pm »
Btw keysight will not sell you any if you are not buying via corporate account.
In my case i was politely sent into erotic hiking.
Offline yo0Topic starter
  • Country: mx
« Reply #26 on: June 24, 2017, 01:14:58 pm »
Yes, waiting Monday to call keysight
Offline HighVoltage
« Reply #27 on: June 24, 2017, 01:46:10 pm »
I took the relay of my 34410A apart
Here are the tear down pictures again, since we talk so much about this relay.
  • Country: mx
« Reply #28 on: June 24, 2017, 03:00:15 pm »
ops! when you say corporate account do you mean ANY company? and no sells to individuals?
best regards
Pio
« Last Edit: June 24, 2017, 04:04:28 pm by yo0 »
Offline Samogon
« Reply #29 on: June 24, 2017, 04:05:36 pm »
Yes, no sales to individuals
« Last Edit: June 24, 2017, 04:47:20 pm by Samogon »
  • Country: mx
« Reply #30 on: June 24, 2017, 04:12:30 pm »
Yes, no salas to individuals
thank you, i need to be creative when talk with them.  ;D
best regards
Pio
Offline Samogon
« Reply #31 on: June 24, 2017, 04:48:36 pm »
Not gonna fly
They will ask for payment method and delivery address to be a company
  • Country: mx
« Reply #32 on: June 24, 2017, 04:55:43 pm »
Not gonna fly
yes i know that, let see Monday :)
i´ll keep you informed
Pio
  • Country: mx
« Reply #33 on: August 01, 2017, 04:49:34 am »
since the relay most common failure is mechanical related, just did a reflow on the removed from pcb k101 relay (aprox 330°c about 20-25 seconds) in both relay reed pins, reinstalled to pcb and it is working stable as should be again for several weeks, hope this help somebody.
another option is the coto 3501-05-91X, the only trade off is the maximun voltage is reduced to about half (think is more than adequate for most people needs), the other functions operation limits are almost the same, but this part number is much more available than the heaftier model 3540-05-91x
update: Feb 5, 2023,  unit still working fine!  :D
best regards
Pio
« Last Edit: February 05, 2024, 07:09:13 pm by yo0 »
Offline pete99
« Reply #34 on: November 07, 2017, 05:11:09 am »
I also have a bad k101 relay.  I tried to purchase from Keysight but I was rejected because I no longer have a company email.  I am a retired test engineer from an aerospace/defense company, that purchased hundreds of thousands of dollars in HP and Agilent test equipment over my career and get rejected to purchase a $50 part.  Pretty funny.  I've contacted Coto in Germany and they referred me to Keysight.
  Do you have any other suggestions?
Thanks so much,
Steve
Offline HighVoltage
« Reply #35 on: November 07, 2017, 07:50:23 am »
Thanks so much,
Steve
Steve
I have tried to buy from Coto for years and it is not working, because this special relay was built for Agilent/Keysight only. I have ended up, buying it from Keysight directly.
Send me a PM.
Offline pete99
« Reply #36 on: November 07, 2017, 08:35:15 pm »
Thanks for the reply.  I sent a message to Keysight sales, so waiting to see how they respond.  In the meantime, I went ahead and ordered a Coto suggested substitute from Testco, the 3540-05-911.  One of it's ratings is 500v instead of the Keysight 1000v rating which doesn't concern me.  I'll let you know how it works out.  Do you use the 34401 at home or at your job (or both)?
All the best,
Steve
Offline HighVoltage
« Reply #37 on: November 08, 2017, 08:11:05 am »
I have plenty of 34401A instrument and use them at work and at customer places installed in test stands and also a few at home for hobby use. They are great and reliable for many years, if treated well.
Offline pete99
« Reply #38 on: November 10, 2017, 08:07:29 pm »
Here is the current status of my 34401A Relay repair.
I ordered and received the Coto relay from Testco (distributor).  The part number is 3540-05-911.  I think it was approx $32 US.  It is rated at 500v instead of the HP/Keysight rating of 1000v.  It has an extra pin between the two coil pins.  Not sure what it's connected to, I just bent it over.  I installed the relay and after testing and running for 2 days, it appears to be working just fine.
  In the meantime, I had sent an email to Keysight sales and they replied with a quotation.   So I went ahead and made up a purchase order and emailed it back to them (usa_orders@keysight.com, they probably have an address for overseas orders).  I was asked to call (800 829-4444) to agree with their terms and supply a credit card number.  They ship 2 day delivery at no charge.  They have a $50 US minimum, but this part price is $52.86 US, so all appears to be good.
Thanks again for your help,
Steve
