Author Topic: Current clamp hall sensor IC  (Read 353 times)
Offline Simon123Topic starter
  • Country: si
    • Youtube channel
« on: May 01, 2024, 06:11:12 pm »
Hello!
I have this current clamp with broken hall sensor ic (Leads cracked off from the, cant solder to it)
Could anyone help me with identifying this SMD hall sensor? Current clamp is TECPEL DMC039 aka. extech 380941
It looks like it says .Q.
Thank you in advance, Simon
Offline floobydust
Re: Current clamp hall sensor IC
« Reply #1 on: May 01, 2024, 07:34:05 pm »
Similar Hall sensor was ID'd in this thread, there's a link to some parts to confirm marking code.
https://www.eevblog.com/forum/repair/fluke-337-clamp-meter-hall-sensors/msg5350238/#msg5350238
  • Country: si
    • Youtube channel
« Reply #2 on: May 01, 2024, 07:38:01 pm »
Saw that. Mine appears to have all 4 pins of same width.
  • Country: si
    • Youtube channel
