Author Topic: Agilent 54621A with corrupt cal factors  (Read 1505 times)
Offline SjokoladeTopic starter
  • Country: no
« on: October 19, 2017, 08:12:29 am »
The coin battery on this scope is measuring 0 voltage, if I fit a new battery can I still use the scope or will the measurements be way off  ?
« Last Edit: October 19, 2017, 08:14:10 am by Sjokolade »
If at first you do succeed try not to look astonished
Offline Gyro
Re: Agilent 54621A with corrupt cal factors
« Reply #1 on: October 19, 2017, 08:58:51 am »
Given that it is reporting that everything is corrupt anyway, I don't think you have anything to loose.
I don't know if you are able to test it's measurement accuracy at the moment but I don't think changing the battery will make it any worse than it is now.
Best Regards, Chris
  • Country: no
« Reply #2 on: October 19, 2017, 06:23:28 pm »
Going to replace the battery and see what happens, fan is noisy so I'm replacing that too.
Thanks
