I got a Agilent 54622 that has an issue with the digital acquisition.
Digital channels 2, 5, 6 and 7 are stuck in low.
The acquisition circuit of each channel starts with a cap, then a resistor then the acquisition ASIC.
Then probing these channels on the node between the capacitor and resistor or between the resistor and the ASIC the signal is killed and pulled to -4.5v.
Has anyone come across this issue before or has some experience with these Agilent MSOs?
