Author Topic: HP34401a screen repair  (Read 3279 times)
Offline sabahanTopic starter
  • Country: my
« on: October 27, 2016, 07:44:54 am »
I bought a worn HP34401a with the display not displayed in full,the florescent some a not lid,I manage to get a replacement from eBay but how to I remove the old one from the meter,I read the instruction online ,the instruction just mention remove the screen but did not mention how,anyone have experience?please help
Offline HighVoltage
Re: HP34401a screen repair
« Reply #1 on: October 27, 2016, 07:49:35 am »
Welcome to the forum
Download the 34401A service guide. On page 151 you will find an illustration of how to remove the front panel. Once you have removed the front panel, the rest is almost self explanatory to exchange the front panel PCB.
Offline bitseeker
« Reply #2 on: October 28, 2016, 12:56:11 am »
Hi sabahan,
Welcome to the forum. Did you buy a replacement front panel PCB, on which a VFD module is already mounted, or just the VFD module (i.e., only the glass display)?
When you say "remove the screen" are you referring to (1) removing the front panel from the chassis, (2) removing the front panel PCB from the front panel, or (3) removing the VFD module from the front panel PCB?
Offline coldframe
  • Country: kr
  • Math isn't lie.
« Reply #3 on: October 28, 2016, 02:17:34 am »
Hello sabahan
VFD(Vacuum Fluorescent Display) is irrepairable part.
Replace, For now this is the best way to go
Have a read of this article
VFD display for HP 34401a multimeter wanted
https://www.eevblog.com/forum/buysellwanted/vfd-display-for-hp-34401a-multimeter-wanted/msg197353/#msg197353
coldframe.
« Last Edit: October 28, 2016, 03:16:56 am by coldframe »
Offline BFX
  • Country: sk
Offline eb4eqa
« Reply #5 on: October 28, 2016, 01:45:32 pm »
That VFD module from eBay does work and it is new, but it is not original. I've installed one and it is not nearly as bright as the original one. Only way to go if you have a severely dim one or if do not have one at all...
Roberto EB4EQA
