Author Topic: Prisma elevator door controller, damaged psu, need identify components  (Read 2559 times)
Offline Harry_22
Re: Prisma elevator door controller, damaged psu, need identify components
« Reply #25 on: December 08, 2024, 02:00:15 pm »
Zeners can be 13 volts. This is enough to start the controller (Vcc=9V max).
The main thing is that after start-up Vcc voltage rises slightly (up to 10-11 volts) and turns off Q32.
Offline timeandfrequency
« Reply #26 on: December 08, 2024, 08:56:32 pm »
Buy also a replacement for R114 (100 k).
10 k seems pretty low (lead to a start current of  I = 31 mA)
If the controller does not start with 100 k, you can still try 10 k in a second attempt.
« Last Edit: December 08, 2024, 08:58:49 pm by timeandfrequency »
Offline Harry_22
« Reply #27 on: December 08, 2024, 09:48:04 pm »
100k resistor will not burn out as much as 10k in case of Q32 short.
« Reply #28 on: December 08, 2024, 10:09:32 pm »
I already noticed your explanation above.
Let me just allow to have different opinion than yours.
« Last Edit: December 08, 2024, 10:11:50 pm by timeandfrequency »
The following users thanked this post: Harry_22
Offline Poroit
« Reply #29 on: December 09, 2024, 05:40:24 am »
G'day All,
I am not sure if the attached is a help or a hinderance but it contains similar components to the damaged PSU.
I have seen similar damaged components in these as well.
I do not have a schematic.
Offline Harry_22
« Reply #30 on: December 09, 2024, 10:42:54 am »
G'day All,
Hi Poroit!
Yes, yours PSU is mostly similar.
PFC provides its own Vcc supply. That is why low power start-up UCx845 is used there.
Also 50% duty cycle is usually used with the high power transformer.
« Reply #31 on: December 09, 2024, 09:20:45 pm »
Hello Poroit,
G'day All,
Can you confirm that the document you provided shows an elevator door controller from Prisma ?
« Reply #32 on: December 09, 2024, 09:34:29 pm »
About Z14  (Vz = 11 V in the latest schematic)
@PiotrMisiuna Any marking on the zeners ?
Minimum PWM controller startup voltage depends on IC reference :
UC3842 &  UC3844 : 16 VDC   :  Z14 value is underrated, PWM controller will not start
UC3843  &  UC3845  : 8,4 VDC  : Z14  value is OK
Interesting sentence in chapter '7.3.5 Undervoltage Lockout' of the datasheet :
During normal circuit operation, VCC is developed from auxiliary winding NA with DBIAS
and CVCC. At start-up, however, CVCC must be charged to 16 V (*) through RSTART. With a start-up current of 1 mA,
RSTART can be as large as 100 kΩ and still charge CVCC when VAC = 90 V RMS (low line). Power dissipation in
RSTART is then be less than 350 mW even under high line (VAC= 130 V RMS) conditions.
(*) Actual minimal startup voltage depends on IC model, see above.
Reminder : as PiotrMisiuna is located in Europe, VAC = 240 V RMS @ 50Hz (hence DC rail voltage = 339 VDC)
« Last Edit: December 10, 2024, 09:39:38 am by timeandfrequency »
Offline Poroit
« Reply #33 on: December 10, 2024, 05:36:16 am »
G'day timeandfrequency,
Unfortunately not.
It is an SMPS from a 25 year old Air Data Test Set.
The following users thanked this post: timeandfrequency
« Reply #34 on: December 10, 2024, 09:47:25 am »
Unfortunately not.
Thanks Poroit for this information.
These UCx84x switchers have numerous applications and were used in many different designs.
This thread is about the repair of a 'Prisma elevator door controller'.
Unfortunately, the board you showed can not really be used as reference to identify the fried parts we have on that elevator controller.
« Last Edit: December 10, 2024, 01:01:41 pm by timeandfrequency »
The following users thanked this post: Poroit
Offline PiotrMisiunaTopic starter
  • Country: cy
« Reply #35 on: January 18, 2025, 08:42:28 pm »
I believe the repair is successful. Powered up on the workbench effected in one of  LED lights going red and some relays going click.  Now I will pass it and wait for feedback from the elevator technician.  :)
The following users thanked this post: timeandfrequency, Poroit
That's good news.
Keep us updated.
If possible, post again the latest version of the schematics, with the actual parts values/references you used to repair the board.
