Author Topic: Agilent E3616A PSU, dead [FIXED]  (Read 5428 times)
Offline HighVoltageTopic starter
« on: August 23, 2015, 12:39:21 pm »
My Agilent E3616A is from 2007 and suddenly died.
After "turn on", the display shows random stuff and nothing happens on the output and OVP light comes on right away.
I was looking for the schematics but there is nothing on the Keysight website.
It seems like Agilent has pulled service manuals and schematics already in 2007.
http://www.keysight.com/main/editorial.jspx?cc=AL&lc=eng&ckey=1000000367:epsg:man&nid=-536902299.384304.00&id=1000000367:epsg:man
There is the operating manual that even says "Service Manual" on the cover page but is has no usable content for repairing this PSU.
Does someone here might have a full schematic?
Thanks.
« Last Edit: August 23, 2015, 04:59:57 pm by HighVoltage »
Offline Deathwish
  • Country: wales
Electrons are typically male, always looking for any hole to get into.
trying to strangle someone who talks out of their rectal cavity will fail, they can still breath.
God hates North Wales, he has put my home address on the blacklist of all couriers with instructions to divert all parcels.
Re: Agilent E3616A PSU, dead
« Reply #2 on: August 23, 2015, 01:34:49 pm »
Thank you Deatwish,
But that one is the same as the one on the keysight website or many others that I found
The oldest one I found was by HP from 1999 and it also does not include the service manual / schematics.
Since this PSU was already made during the HP time, one would think that it is easy to find a good schematics.
I will keep looking.
« Reply #3 on: August 23, 2015, 01:44:00 pm »
I found the schematics and parts list here:
https://github.com/ee-lco/e361xa/blob/master/doc/AgilentE361516AManual.pdf?raw=true
The schematics was annotated by someone but it is ok to use.
Now the trouble shooting will begin.
The following users thanked this post: najrao
« Reply #4 on: August 23, 2015, 02:00:01 pm »
OK, I found a big problem on the rails
U13 is a LM317 and is suppose to be at +15V
Measured 1.2 Volts
U14 is a 7912 and shows no output at all
The input from the transformer seems to be OK.
So, I will exchange those two regulators and see what happens...
« Reply #5 on: August 23, 2015, 02:22:24 pm »
With them out check the input voltages to the regulators and if there is not a short on the output. Strange that both rails go at the same time, I would suspect the output has a short somewhere, or R108 has gone open.
« Reply #6 on: August 23, 2015, 03:56:39 pm »
@SeanB
Thanks for the feedback.
R108 was OK
No shortage on the outputs.
All capacitors OK and both diodes (CR31, CR32) are OK
I installed two new regulators and the PSU works perfectly!
Almost too god to be true and a big surprise, but even the calibration is spot on.
To the failure:
Yesterday I used the Agilent PSU to supply 12V at 500 mA to a cascading high voltage DC supply.
I think some high voltage spikes must have traveled back to the Agilent PSU.
So, bottom line... 2 new regulators and couple hours of work and the power supply works like new.
Offline BFX
  • Country: sk
Re: Agilent E3616A PSU, dead [FIXED]
« Reply #7 on: August 23, 2015, 11:34:04 pm »
Good job :-+ Zum Wohl! :beer:
