Author Topic: Agilent E3616A PSU has shortage  (Read 478 times)
Offline HighVoltageTopic starter
« on: March 25, 2021, 04:13:00 pm »
This E3616A PSU has suddenly turned off and the 1A fuse is blown.
This PSU is used on 230V
The problem is around the power resistor R1, because it is overheating.
Removing R1 stops the short.
R1 is 0.6 Ohm and from the looks around 10W
I checked the surrounding components in the trace and can not find the problem.
Enclosed is the schematic.
Anyone here have some ideas what the problem might be or what the next step would be?
Thanks for any help.
« Last Edit: March 25, 2021, 04:19:25 pm by HighVoltage »
Offline pqass
Re: Agilent E3616A PSU has shortage
« Reply #1 on: March 25, 2021, 05:12:03 pm »
R1 and R2 are for leveling the current through the main series MOSFETS Q1 and Q4.  A low, sub-ohm value is expected.
If you've removed R1, replaced the fuse, and turned it on again without issue, then it may indicate that Q1 has been permanently shorted.   Remove Q1 and test it.
