Author Topic: Fixing an EX330 Dial Prong Failure  (Read 463 times)
Offline KitsuneMulderTopic starter
« on: June 02, 2020, 04:32:21 am »
I bought this as is and did a temporary fix but not sure if someone has any idea a better permanent fix. Basically on two sides of the prong it dug through the plastic. I used a small piece of tape but something that fills it correctly would be preferable.
Thanks all!
