I agree that it's likely the
PLL chip (corrected: Frac-N chip is what I meant -- that's where my testing seemed to point as well. Good luck finding new chips!). I had the same problem with my E4433A and was fortunate to find a complete working synthesizer board from an eBay seller in Moscow. One day, I'll repair the original board.
For connectors, I learned somewhere on here that the board RF connectors are compatible with D-sub coax connectors. I've bought Harting 09-69-281-7140 (female), 09-69-181-7140 (male) and also
09-69-181-5140 (male) and none work. The center pins are all too thick.
Leo, do you think
this might work? It's 50 ohms.
(Better option at this link)*BTW, Leo, I'm suddenly a fan of yours after seeing your pulse generator on
The Signal Path (Hugoneous' YouTube channel) and then checking out your web site!
