Author Topic: iPhone 11 battery connector pinout  (Read 2118 times)
Offline 2XTopic starter
  • Country: gr
« on: July 09, 2023, 03:36:40 pm »
Hello,
I measure the battery of an iphone 11 and I measure in all pins 0V. Does anyone knows what voltage I have to measure in every pin (attached photo)? On android batteries where have 4pin one is Positive, one GND, one Battery Status and one Battery Temperature. On this battery there are 6pin.
« Last Edit: July 09, 2023, 10:55:51 pm by 2X »
Offline Jane
Re: iPhone 11 battery connector pinout
« Reply #1 on: July 12, 2023, 07:38:10 pm »
You'd better ask in a forum about cell phones e.g.
https://forum.gsmhosting.com/vbb/f1086/
The following users thanked this post: 2X
Offline Alfi1966
« Reply #2 on: July 14, 2023, 07:22:40 am »
You will not measure a voltage when unconnected. If the data lines are not talking to the charge controller the FET's in the battery pcb will not open.
Found some info here. Hope it helps: https://logi.wiki/index.php/File:iPhone_11_Connector_1.jpg
  • Country: gr
« Reply #3 on: September 17, 2023, 08:06:21 pm »
 With only connected the connectors 1 & 2 the current that draw the iphone is about 500mA (if I disconnect the connector 1 the current falls to zero). This current is normal with olny these connectors connected? Also, there is a way to fix the Charging Flex (if it is indeed the problem there)?
  • Country: gr
« Reply #4 on: October 11, 2023, 09:02:51 pm »
Finally I changed only the LCD screen and worked flawless.
