hello
Unit did not power on. no fans working.
Fault was traced to a defective TOP223Y Ic in the power supply side board and an open 10ohms MOX resistor
After replacing unit powers on and shuts down after a minute . repeated power on cycles from the front panel power on key results in unit powering on and fans running a constant speed. no display though. Once it starts stays it remains on .no display when the power on soft key is depressed the unit powers off. when the mains is switched off again the fan rpm increases before shutting down.
ALl the lv supplies ok. 3.3, 5v -5 and 12 v
thinking of connecting an external monitor and replacing the CR2032 battery
Regards
Anand
