Author Topic: Need help identifying a component  (Read 675 times)
Offline electroguy98Topic starter
  • Country: in
« on: December 19, 2019, 10:36:36 am »
Hello..I was trying to replace the left analog stick of my ps4 controller and while heating the solder pads with a hot air gun I burnt the connector circled in the picture. I need help in identifying the component and also from where I can get it. If not possible then please let me know if there's an alternative.🙏🙏
Thanks
Offline Psi
Re: Need help identifying a component
« Reply #1 on: December 19, 2019, 11:10:25 am »
Need a much higher res /closer image for us to positively identify it.
  • Country: in
« Reply #2 on: December 19, 2019, 11:20:50 am »
Here is a link to the website which has the images:
https://www.acidmods.com/forum/index.php?topic=43542.0
  • Country: in
« Reply #3 on: December 19, 2019, 04:00:52 pm »
Please sir help me I couldn't find any other high resolution images but I can tell that a 12-pin flex ribbon cable attaches into the burnt/destroyed connector. Let me know if this helps🙏
Offline LateLesley
  • Country: scotland
« Reply #4 on: December 19, 2019, 04:37:53 pm »
I think this may be it - https://www.aliexpress.com/item/4000073381392.html?spm=a2g0o.productlist.0.0.326d2b8bAqdFLz&algo_pvid=9ce9f335-f639-41c6-8adf-57c10d6ecba6&algo_expid=9ce9f335-f639-41c6-8adf-57c10d6ecba6-7&btsid=f6fd323e-3842-444b-90ea-e9ea365049bf&ws_ab_test=searchweb0_0,searchweb201602_10,searchweb201603_53
If you search for FFC-12P SMD or FPC-12P SMD connectors you should find them. I can only find 50pcs or 100pcs on ali, but with a bit of googling, you might find them in single quantities.
The following users thanked this post: electroguy98
  • Country: in
« Reply #5 on: December 19, 2019, 04:41:08 pm »
Thanks a lot🙏🙏... I'll check it out
The following users thanked this post: LateLesley
