Author Topic: Agilent N5747 Power Supply OUP Error  (Read 1944 times)
Offline dundeeTopic starter
« on: March 06, 2017, 06:45:25 pm »
Hi Guys!
I scored an Agilent N5747 power supply (60V / 12.5A ) .
Pictures: https://www.dropbox.com/sh/8g3jg55eqle50jv/AABUiFE4NXSTDNbqPttIDrI3a?dl=0
It shows direct on startup "OUP" on the Display and Protect ist flashing. The local sense wires at the back are connected.
Measured 0 to 5 Volts varying at the Output with DMM.
The pcb's are in good physical condition. Nothing burned to see.
I refered to the manual. OUP is normally active when the OVP-Protection is triggered.
But OVP is set to the Maximum (66V).
It looks like there are no service manuals or schematics available. The original design is from TDK-Lambda (Genesys Series).
Could it be that the calibration is missing? Anny other suggestions?
Best Regards
Steffen
« Last Edit: March 06, 2017, 07:18:28 pm by dundee »
