The amount of work some people go through to scam ya...sheesh
Anyhow, here's some pictures to show what I see.
The power supply is 12.2VDC. that is coming out the battery connector along with 2.00vdc (for temp sensor?)
Does anyone recognize the Battery connector plug type so I can order a plug for it to build a battery?
All the diodes seem to measure good. The coin battery soldered to the board is depleted to 0.3vdc
I'm guessing it should be 3V +?
I have ordered a ESR meter. Its making its way to me from Japan.
Its hard to know what to test next. If you have suggestions, I'm all ears! If you would like more pictures of a different angle or a close-up, please ask.
I am pretty new at this as you can probably tell.
Thanks for reading this
