Author Topic: Agilent U1604A 40MHz Handheld Dual Channel Digital Oscilloscope  (Read 2853 times)
Offline HandBuiltTopic starter
Hello all !
I recently picked up on of these handhelds from ebay. It does not power up, no led ...zip. There is voltage getting to the battery three pin connector when I plug in the power supply.
It did not come with a battery and only one screw holding the covers on  :palm: Someone has been poking around
Does anyone know if the unit will power up without the battery connected?
Could someone kindly help me track down a schematic for this unit please. It has a multi level pc board so its a bit tough to trace.
Cheers !
« Last Edit: April 06, 2018, 03:36:43 pm by HandBuilt »
Offline Samogon
Re: Agilent U1604A 40MHz Handheld Dual Channel Digital Oscilloscope
« Reply #1 on: April 06, 2018, 07:20:47 pm »
If i remember correctly it was required battery to startup.
The following users thanked this post: HandBuilt
« Reply #2 on: April 07, 2018, 06:13:37 pm »
Shoot, thought I found a schematic
http://www.circuit-encyclopedia.com/showinfo-30-396287-0.html#ecms
come back with a 404 error
"contact us" just brings you back to the top of the page.
Offline Samogon
« Reply #3 on: April 07, 2018, 06:38:22 pm »
Most of the sites claiming that they have unobtainium schematics and service manuals are fakes.
« Reply #4 on: April 07, 2018, 08:40:46 pm »
The amount of work some people go through to scam ya...sheesh
Anyhow, here's some pictures to show what I see.
The power supply is 12.2VDC. that is coming out the battery connector along with 2.00vdc (for temp sensor?)
Does anyone recognize the Battery connector plug type so I can order a plug for it to build a battery?
All the diodes seem to measure good. The coin battery soldered to the board is depleted to 0.3vdc
I'm guessing it should be 3V +?
I have ordered a ESR meter. Its making its way to me from Japan.
Its hard to know what to test next. If you have suggestions, I'm all ears! If you would like more pictures of a different angle or a close-up, please ask.
I am pretty new at this as you can probably tell.
Thanks for reading this  :)
« Last Edit: April 07, 2018, 08:48:16 pm by HandBuilt »
« Reply #5 on: June 12, 2018, 02:55:16 am »
 If you own one of these units could I please ask to check if it will power up without the 7.2V Battery Pack  :-+
Offline lowimpedance
  • Watts in an ohm?
« Reply #6 on: June 12, 2018, 06:46:41 am »
Work has a U1602a, I just checked and it does power up without the battery pack connected.
No reason to assume the 1604 should be any different in this respect.
« Reply #7 on: June 12, 2018, 01:59:43 pm »
Thank you! That was a big help, Cheers!
Offline DKMac@home
« Reply #8 on: August 22, 2020, 03:44:08 pm »
Are you still playing with this U1604A Scopemeter
I am currently play wit a u1604B model that had the scope fuctions working but no data diplayed in DMM modes, just the dc symbol and the linear bar gragh shown. No reading for Dc,AC,Ohms,Diodes mode
