Author Topic: Agilent/HP 8648 B/C/D Firmware re-programming  (Read 1739 times)
Offline USMC_SpikeTopic starter
« on: November 17, 2017, 08:46:14 pm »
Hi Gents,
Anyone have experience reprogramming the firmware
so that after upgrading one or more boards,
that is the upgrade options, on the HP 8648 b/c/d
the unit works and functions properly?
I think there might be some folks out there,
including me, that could benefit from this.
Thanks, ?
Cheers,
USMC_Spike
Offline mmaseda
Re: Agilent/HP 8648 B/C/D Firmware re-programming
« Reply #1 on: January 09, 2018, 03:24:00 am »
Did you ever get a response?
Offline Melt-O-Tronic
  • Brilliant with a slaughtering iron in my hand!
« Reply #2 on: January 09, 2018, 03:25:13 am »
I'm interested in this too.
« Reply #3 on: May 13, 2018, 09:35:43 am »
Nope never a response and it is needed.
Go figure.
Cheers,
USMC_Spike
Offline SaabFAN
« Reply #4 on: May 13, 2018, 11:03:48 am »
What kind of processor is used inside the device?
Is the way the CPU talks to the rest of the hardware documented somewhere?
If not, it'll be quite difficult to reverse-engineer the functions just from the machine code.
Offline LateLesley
  • Country: scotland
« Reply #5 on: May 13, 2018, 11:27:02 am »
I did a bit of googling, and you all may be interested in THIS
Specifically, it has a Motherboard Utility, where I think you can pick the options added to your device.
« Last Edit: May 13, 2018, 11:32:06 am by LateLesley »
The following users thanked this post: rhb
