In opening and closing the case of my 8648C signal generator I accidentally caught a fold of the keypad ribbon cable in the case closure. This severed at least several of the conductors, leaving the instrument inoperative.
At first, I thought I might repair the breaks by carefully peeling back the outer plastic layer and soldering jumpers across the break, but quickly learned the very thin foil layer flaked and fell off. It seems this connecting ribbon is not separately replaceable without replacing the keyboard membrane, so I considered methods of repairing it in place. At first I thought the 16-pin connector used to connect the ribbon cable to the motherboard was designed to puncture through the ribbon conductors by closing the housing, however, by looking at ribbon cable connectors online, it appears they are designed to contact pads on the printed circuit. I thought as there is sufficient slack in the cable, if I could obtain a comparable pair of male and female connectors, I could cut the ribbon at the damage point and install these connectors to close the gap; however, I am wondering whether I could properly prepare the cut ribbon ends.
There are no markings on the ribbon connector. Can anyone direct me to suitable products and installation requirements? Has anyone else had this happen and devised a suitable method of repair?
I have been considering drilling #80 (0.0135-inch) (0.34 mm) holes through the conductors, on either side of the breaks, filling these with solder paste, inserting fluxed sections of #30 AWG (0.01-inch) (0.25 mm) wire across the breaks, and heating the wire to hopefully connect to the foil and bridge the gaps. Does this seem worthwhile trying?
Bruce, KG6OJI
